HMIN_mbplane_write()
Writes multibody planes to HyperMesh.
void HMIN_mbplane_write (HM_entityidtype id, char *name, unsigned char color, int type, double origin[3], double xaxis[3], double yaxis[3], HM_entityidtype multibodyid);
HyperMesh hminlib Function
id
The ID of the multibody plane.
name
The name of the multibody plane.
color
The color assigned to the multibody plane.
type
The type assigned to the multibody plane.
origin
Coordinate of the origin node of the plane.
xaxis
Coordinate of the x-axis node of the plane.
yaxis
Coordinate of the y-axis node of the plane.
multibodyid
The ID of the multibodies.
None.
