HMIN_laminate_write_entities()
Assigns a ply or sub laminate to a laminate.
void HMIN_laminate_write_entities(HM_entitytype entity_type, unsigned int num_entities, HM_entityidtype *entity_ids);
HyperMesh hminlib Function
Assigns a ply or sub laminate to a laminate. Must be called after HMIN_laminate_write().
entity_type
The type of entity to write.
num_entities
The number of entities to write.
entity_ids
The IDs of the entities.
None.
Version History
11.0
