HMIN_dictionary_write()
Transfers a dictionary into a collector.
void HMIN_dictionary_write(int entities, HM_entityidtype entityid, char * name, char * typename, char * string, double value, int active);
HyperMesh hminlib Function
entities
The type of entity (HM_ENTITYTYPE_COMPS, HM_ENTITYTYPE_LOADCOLS, HM_ENTITYTYPE_SYSTCOLS, HM_ENTITYTYPE_GROUPS, HM_ENTITYTYPE_MATS).
entityid
The entity ID that should be assigned to the dictionary.
name
The name of the dictionary item.
typename
A name assigned to a character string that is "none," "real," "integer," or "string."
string
A character string associated with the dictionary.
value
The value associated with the dictionary.
active
The activity status associated with the dictionary item. Activity can be set to:
  • -1 If the dictionary is not selectable.
  • 0 If the dictionary is selectable, but is set to off.
  • 1 If the dictionary is selectable, but is set to on.
See Template Chapter of the HyperMesh Reference Manual.
None.
