HMIN_designvar_writelaminate()
Assigns a laminate to a topology, topography or gauge design variable.
void HMIN_designvar_writelaminate(HM_entityidtype laminate_id);
HyperMesh hminlib Function
Assigns a laminate to a topology, topography or gauge design variable. Must be called after HMIN_designvar_write().
laminate_id
The ID of the laminate to be assigned.
None.
Version History
11.0
