Creating a Current Request
Create a current request by searching and navigating the documentation.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Learn the terminology of automation to create an automation script.
Learn to navigate the API documentation to find the correct syntax for an automation script.
Learn to navigate the API documentation to create a patch antenna using an automation script.
Create a new empty project in CADFEKO.
Create a rectangle by searching and navigating the documentation.
Create a dielectric medium by searching and navigating the documentation.
Create a second dielectric medium by searching and navigating the documentation.
Create a planar multilayer substrate by searching and navigating the documentation.
Create a feed pin by searching and navigating the documentation.
Create a wire port by searching and navigating the documentation.
Create a voltage source by searching and navigating the documentation.
Set the frequency by searching and navigating the documentation.
Create the mesh by searching and navigating the documentation.
Create a far field request by searching and navigating the documentation.
Zoom to the extents of the 3D view to view the entire model and far field request.
Enable the parallel Solver by searching and navigating the documentation.
Save the CADFEKO model to a .cfx file by searching and navigating the documentation.
Run the Solver by searching and navigating the documentation. Enable a parallel solution, save the model and run the Solver.
View the completed CADFEKO automation script.
Post-process the results of a patch antenna on a multilayer substrate.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Design matching antenna circuits with Optenni Lab and use the circuit in Feko.
Design a bandpass coupled line filter with Altair HyperStudy as optimisation engine and Feko as the computational solver.
my_currents = this_config.Currents:Add()
