Creating a Voltage Source
Create a voltage source by searching and navigating the documentation.
Search for voltagesource in the integrated help.
The results returned in response to the voltagesource query includes VoltageSource (object).
- Double-click VoltageSource (object).
View the VoltageSource (object).
Note: Since there can be multiple voltage sources in the model, the voltage source object is part of a collection.
Figure 1. A snippet of the VoltageSource object which shows the Parent Collection List. -
Click SourceCollection hyperlink to navigate to the
SourceCollection description.
Figure 2. A snippet of the SourceCollection which shows the Usage locations.Note: A voltage source is configuration specific. It can be added to either a standard configuration or a characteristic modes configuration.
We want to add the voltage source to the default configuration (standard configuration).
Search for StandardConfiguration in the integrated help.
Double-click StandardConfiguration (object).
View the standard configuration object.
Note: Since there can be multiple standard configurations in a model, the standard configuration object is part of a collection.
Figure 3. A snippet of the StandardConfiguration object which shows the Parent collection list. -
Click the SolutionConfigurationCollection hyperlink to
navigate to the SolutionConfigurationCollection
description.
Note: The application project contains the StandardConfiguration.
Figure 4. A snippet of the SolutionConfigurationCollection which shows the Usage locations (collections).The prepending syntax is as follows.Project.SolutionConfigurations
Go back to SolutionConfigurationCollection in the integrated
help.
Note: The Index list indicates you can reference the specific StandardConfiguration through indexing with the use of a number or a string.
Figure 5. A snippet of the SolutionConfigurationCollection which shows the Index list. -
Create a separate handle for the configuration.
this_config = my_project.SolutionConfigurations[1]
Tip: It is not necessary to create a separate handle for the StandardConfiguration, but is convenient for adding more configuration specific objects. -
Add the voltage source using the following syntax.
my_voltage_source = thisConfig.Sources:AddVoltageSource(myPort)
