Configure Host-level Custom Resources
Configure a dynamic host-level custom resource such as scratch space.
Dynamic Host-level Resources
Use a dynamic host-level resource to query the MoMs to get the availability of a resource and use that value for scheduling.
For dynamic host-level custom resources, the scheduler sends a resource query to each MoM to get the current availability for the resource, and uses that value for scheduling. If the MoM returns a value, this value replaces the resources_available value reported by the server. If the MoM returns no value, the value from the server is kept. If neither specifies a value, the scheduler sets the resource value to 0.
The available amount of the resource is determined by running a script or program which returns the amount via stdout. This script or program is specified by the Mom Resources parameter.
The script is run once per scheduling cycle. For a multi-vnode machine, the script is run for the natural vnode. The resource is shared among the MoM’s vnodes.
The scheduler tracks how much of each numeric dynamic server-level custom resource has been assigned to jobs, and will not overcommit these resources.
The format of a dynamic host-level resource query is RESOURCE_NAME !PATH_TO_COMMAND where RESOURCE_NAME is the name of the resource and PATH_TO_COMMAND is typically the full path to the script or program that performs the query in order to determine the status and/or availability of the new resource you have added.
An example of a dynamic host-level resource is scratch space on the execution host.
Host dynamic resource values are never visible in qstat, and have no resources_available.RESOURCE_NAME representation anywhere in PBS.
Configure Dynamic Host-level Custom Resources
Configure a dynamic host-level resource to query the MoMs to get the availability of a resource and use that value for scheduling.
Important: The MoM Resources parameter can only be updated if the cluster was added by a user with passwordless sudo permissions and therefore may not appear as a Scheduling parameter.
  1. Click the Configure tab.
  2. Choose the HPC to configure.
    Choose an HPC
    Figure 1. Choose an HPC
  3. Click Scheduling from the PBS Professional menu located on the left-hand side of the web page.
  4. Click located in the upper right-hand corner of the web page.
  5. Enable the Display Advanced Settings check box.
  6. Click located to the right of MoM Resources.
  7. For MoM Resources, enter the dynamic host-level resource query in the format: RESOURCE_NAME !PATH_TO_COMMAND
  8. Click to save the change.
