Grant PBS Manager and Operator privileges, specify whether users can query the status of jobs owned by another user, and specify
how usernames are treated across all machines in a HPC cluster.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Use a Formula for Computing Job Execution Priority
Provide a formula that is used to calculate job execution priority.
You can choose to use a formula to sort jobs at the finest-granularity level. When
the scheduler sorts jobs according to the formula, it computes a priority for each
job. The priority computed for each job is the value produced by the formula. Jobs
with a higher value get higher priority.
Click the Configure tab.
Choose the HPC to configure.
Figure 1. Choose an HPC
Click Scheduling from the
PBS Professional menu located on the left-hand side of the
web page.
Click located in the upper right-hand corner of the web page.
Enable the Display Advanced Settings check box.
Click located to the right of Job Sort
Formula.
For Job Sort Formula, enter a formula to calculate job
priority.
The formula can be made up of expressions, where expressions contain terms
which are added, subtracted, multiplied, or divided, and which can contain
parentheses, exponents, unary plus and minus, the ternary operator, and Python
math module functions.
