Specify the prefix that indicates that a queue is a prime time or non-prime time
queue.
Important: The Primetime Queue Prefix and Non-Primetime Queue Prefix
parameters can only be updated if the cluster was added by a user with passwordless
sudo permissions and therefore may not appear as a Scheduling parameter.
Jobs in a primetime queue can start only during primetime. Jobs in a non-primetime
queue can start only during non-primetime.
You define a primetime queue by naming it using the primetime prefix. The default is
“p_”. Similarly, you define a non-primetime queue by prefixing the name. The default
is “np_”.
Parameters for specifying the prefix that indicates that a queue is a prime time or
non-prime time queue.
- Non-primetime Queue Prefix
- Queue names which start with this prefix are treated as non-primetime
queues. Jobs in these queues run only during non primetime.
- Primetime Queue Prefix
- Queue names starting with this prefix are treated as primetime queues.
Jobs in these queues run only during primetime.
Click the Configure tab.
Choose the HPC to configure.
Click Scheduling from the
PBS Professional menu located on the left-hand side of the
web page.
Click located to the right of Non-Primetime
Queue Prefix.
For Non-Primetime Queue Prefix, enter the prefix that
indicates that a queue is a non-prime time queue.
Click to save the change.
Click located to the right of Primetime Queue
Prefix.
For Primetime Queue Prefix, enter the prefix that
indicates that a queue is a prime time queue.
