Prep Data Column Operations
Copy
Operation |
Data Type |
Description |
text, date/time, numeric |
Copies column values only or column values with headers to the clipboard. |
Creates a new table based on the columns and rows highlighted in an existing table. |
filter
Operation |
Data Type |
Description |
text, number, date/time |
Launches the Define Filter dialog to create a new filter to apply to the table. |
Discard All Filters |
Removes all filters applied to the table |
SORT
Operation |
Data Type |
Description |
Sorts the column values in descending order |
Launches the Sort dialog to define a new sort order |
COLUMN
Operation |
Data Type |
Description |
New Formula Column |
Adds a new formula column to the table |
Adds a new constant-value column to the table |
New Lookup Column |
Adds a new lookup column to the table |
Adds a new row-number column to the table |
Adds a new runtime parameter column to the table |
Adds metadata columns to your table |
Changes the column name. |
Creates a copy of a column. |
Hides the selected column |
Removes the selected column from the table. |
Show Hidden Column |
(Displays only when a hidden column exists in a table) Shows a list of hidden columns. Selecting a column from this list displays it in the table once more. |
CASE
Operation |
Data Type |
Description |
text |
Converts to uppercase the first letter of each word in a string. |
text |
Converts all uppercase letters in a string to lowercase letters. |
text |
Converts a string to all uppercase letters. |
CLEAN
Operation |
Data Type |
Description |
text |
Trims all leading and trailing spaces from a string. |
text |
Trims to a single space any sequence of two or more consecutive spaces within a string. It also removes any leading or trailing spaces from the string. |
text |
Removes a sequence of characters from the values of the column you apply this operation to. |
text |
Removes all characters that are not numbers (0-9) or letters of the alphabet (A-Z/a-z) from a column value. |
text |
Removes all numbers from a column value. |
text |
Removes all alpha characters from a column |
CONVERT
Operation |
Data Type |
Description |
text |
Converts a text string to a numeric field. |
text |
Converts text fields with the values “X B,” “X M,” and “X K,” where “X” is any number, into “X,000,000,000,” “X,000,000,” and “X,000,” respectively. |
text |
Converts a string to a date/time. The date format will be: MM/DD/YYYY |
date/time |
Converts a text string containing time information (in HH:MM:SS format) to number of seconds. |
date/time |
Converts a date/time value to text. |
date/time |
Converts a date/time value to number. |
number |
Converts a numeric field to text. |
number |
EXTRACT
Operation |
Data Type |
Description |
text |
Extracts n number of characters from the beginning of a string. |
text |
Extracts n number of characters from the end of a string. |
text |
Extracts n number of characters starting from a position you specify. |
text |
Extracts n number of characters starting from a start and end position indicated by a sequence of characters. |
replace
Operation |
Data Type |
Description |
text |
Replace empty cells with the value of the first non-empty cell above it. |
text |
Replace null values with one more characters. |
text |
Replace blank values with one more characters. |
text |
Substitute a fixed sequence of characters with a different one. |
text |
Substitute a number of characters with a different set of characters starting from a set position. |
split
Operation |
Data Type |
Description |
text |
Starts from the left and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring. |
text |
Starts from the right and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring. |
text |
Splits the value of a single name column into it's component name parts:
text |
Splits the value of a single address column into its component address or postal parts. When you apply this transformation, Prep Data will ask you which of the following name components are available:
date/time |
Splits a date/time field into two or columns according to the date/time components you select. |
date/time |
Splits a date/time field into two or columns according to the ISO 8601 date/time components you select. |
date/time |
Splits a date field into its components fiscal parts. |
Statistics
Operation |
Data Type |
Description |
Displays statistics about a column. Statistics will show you:
Allows you to create a new table including statistics of a row or several rows. |
compute
Operation |
Data Type |
Description |
numeric |
Rounds number to a specified number of places to the right (or left) of the decimal point. |
numeric |
Rounds a number up to the nearest integer. |
numeric |
Rounds a number down to the nearest integer. |
numeric |
Returns the absolute value of the value of a column. |
Remove Decimals (Int) |
numeric |
Returns the Integer portion of a number. |
numeric |
Launches the Calculator dialog, which you can use to create a calculated field via a graphical interface |
OTHERS
Operation |
Data Type |
Description |
Allows you to:
Format (date/time) |
date/time |
Formats date/time columns |
Format (numeric) |
numeric |
Formats numeric columns |
text |
Inserts a constant text string at a specific location in a text field. |
Allows you to merge two columns into one. |
Allows you to redact the values of a column. |
Custom Change > Manage Change Lists |
Allows you to manage custom change lists and convert them into macros. |
Allows you to add or modify macros and apply the same to columns. |
Allows you to remove a column from the table. |
