Altair® Monarch®
Addresses into Parts
Splits the value of a single address column into its component address or postal parts.
  1.
When you apply this transformation, Monarch Data Prep Studio will ask you which of the following name components are available:
Field
Address line 1
Outputs the first line of data extracted from the input information.
Address line 2
Outputs the second line of data extracted from the input information, provided it is not recognized as a City, Region or Postal Code.
Address line 3
Outputs the third line of data extracted from the input information, provided it is not recognized as a City, Region or Postal Code.
Address line 4
Outputs the fourth line of data extracted from the input information, provided it is not recognized as a City, Region or Postal Code.
Address line 5
Outputs the fifth line of data extracted from the input information, provided it is not recognized as a City, Region or Postal Code.
Address line 6
Outputs the sixth line of data extracted from the input information, provided it is not recognized as a City, Region or Postal Code.
City
Outputs the City name extracted from the input information.
Region
Outputs the Region name (State, County, etc) extracted from the input information.
Postal Code
Outputs the Postal Code extracted from the input information.
Country
Outputs the Country name extracted from the input information.
Error Code
Outputs the error code, if any are generated by the Address Block engine when parsing the input information. See Using Address Blocks for more information on Address Block error codes.
Monarch Data Prep Studio will do the postal split depending on the components selected.
INPUT/Output DATA TYPE
Input
Output
text
text
EXAMPLE
In this example, Address is the original column. It is split into three columns: City, Region, and PostalCode.
