/THPART/GRSHEL
Block Format Keyword Defines a Thpart.
/THPART/GRSHEL/Thpart_ID
Thpart_title
grelem_ID
Definition
type Type of input
(see Time Histories (Part definitions) for available keywords)
Thpart_ID Part identifier of the block
(Integer, maximum 10 digits)
Thpart_title TH part title
grelem_ID Element group identifier
  1. A Thpart_ID must be different from all Part_IDs of the deck.
  2. A Thpart can be used, as well as PART in option /TH/PART.
