/PROP/TYPE14 (FLUID)
Block Format Keyword Describes the general fluid property set.
/PROP/TYPE14/prop_ID or /PROP/FLUID/prop_ID
prop_title
Blank Format
qa qb h
prop_ID Property identifier
(Integer, maximum 10 digits)
prop_title Property title
qa Quadratic bulk viscosity
Default = 10-20 (Real)
qb Linear bulk viscosity
h Hourglass viscosity coefficient
Default = 0.10 (Real)
Example (Fluid)
#RADIOSS STARTER
/PROP/FLUID/2
FLUID (unit kg_m_s) data from Example 39 - Biomedical Valve
# blank card
#                q_a                 q_b                   h
               1E-20               1E-20                  .1
#ENDDATA
  1. The qa and qb default values are equal to 1.10 and 0.05 in non-CFD versions.
