/MONVOL/AREA
Block Format Keyword Describes the monitored volume type AREA.
/MONVOL/AREA/monvol_ID/unit_ID | |||||||||
monvol_title | |||||||||
surf_IDex | |||||||||
Blank Format |
monvol_ID | Monitored volume
unit_ID | Optional unit
monvol_title | Monitored volume
surf_IDex | External surface
identifier (Integer) |
- surf_IDex must be defined using segments associated with 4-nodes or 3-nodes shell elements (possibly void elements), and not with /SURF/SEG.
- The volume must be closed and the normals must be oriented outwards.
