/INTER/LAGMUL/TYPE17
Block Format Keyword This interface simulates impact between external surfaces of two brick groups. The external surfaces can only be 16-node thick shell (/SHEL16) elements. Lagrange Multiplier conditions are used in this interface.
These kinematical conditions are only compatible with other Lagrange Multiplier kinematical conditions. This interface formulation is not compatible with SPMD parallel version.
/INTER/LAGMUL/TYPE17/inter_ID/unit_ID | |||||||||
inter_title | |||||||||
grbrc_ID1 | grbrc_ID2 | ||||||||
ITIED |
inter_ID | Interface
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
inter_title | Interface
grbrc_ID1 | First brick group
identifier (16-node thick shells group) (Integer) |
grbrc_ID2 | Second brick group
ITIED | Tied option flag.
(Integer) |
- Both surfaces are defined with two brick IDs and not surface IDs.
- These kinematical
conditions are only compatible with other Lagrange multiplier kinematical
conditions:
- Interface TYPE16
- Interface TYPE17
- Interface TYPE2
- Interface TYPE7
- Boundary condition
- Rigid body
- Imposed velocity
- Rigid wall
- General joints
- Multi-point constraints
