Starter
Only Keyword
Only /AMS must be present in order to apply the AMS to either a designated group of parts, or the entire model, if followed by a blank line (Radioss Starter Input).
CAUTION:
/DT/AMS is mandatory in Radioss Engine Input followed by the scale factor and the targeted increased time step to activate AMS (Radioss Engine Input). Without /DT/AMS in the Engine file, /AMS in the Starter file is ignored.
HMPP / SPMD
If DOMDEC is set to 0, the Starter points to 3 (Multi-level Kway decomposition) by default. Up until version 11.0.230, if /AMS is applied, DOMDEC must be manually switched to 5 (DOF-based Multi-level Kway decomposition). As of version 11.0.240, the Starter automatically sets DOMDEC to 5, if it is set to 0 and if /AMS is present, otherwise, DOMDEC will be set to 3, if /AMS is absent.
Interfaces
  • It is recommended to use Interface stiffness flag Istf = 4 K = max [ S t min , min ( S t max , K n ) ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbGaey ypa0JaciyBaiaacggacaGG4bWaamWaaeaacaWGtbGaamiDamaaBaaa leaaciGGTbGaaiyAaiaac6gaaeqaaOGaaiilaiGac2gacaGGPbGaai OBamaabmaabaGaam4uaiaadshadaWgaaWcbaGaciyBaiaacggacaGG 4baabeaakiaacYcacaWGlbWaaSbaaSqaaiaad6gaaeqaaaGccaGLOa GaayzkaaaacaGLBbGaayzxaaaaaa@4E62@ with K n = min ( K m , K s ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGUbaabeaakiabg2da9iGac2gacaGGPbGaaiOBamaabmaa baGaam4samaaBaaaleaacaWGTbaabeaakiaacYcacaWGlbWaaSbaaS qaaiaadohaaeqaaaGccaGLOaGaayzkaaaaaa@41F6@ and Stiffness scale factor Stfac = 1 (default value) for contact interfaces TYPE7, TYPE11, and TYPE19.
  • If friction is involved, it is advised to set the friction penalty formulation type, Iform to 2 (incremental stiffness for Coulomb friction), whenever this option is available (/INTER/TYPE7, and /TYPE19.
  • For AMS, like in standard mass scaling, it is recommended to not have friction in a TYPE11 contact, if a TYPE7 (already handling friction) contact is already defined for the same parts. This avoids drops of time step and helps model convergence. This recommendation becomes obsolete, if TYPE11 friction is using Iform=2 for edge-to-edge contacts, as of version 13.0.
  • With contact interfaces TYPE7, TYPE11, and TYPE19 using nonlinear penalty stiffness for contact, it might be necessary to use the /DT/INTER/DEL option in the Radioss Engine input deck. Otherwise, AMS may slowly converge, or may diverge.
  • Using /DT/INTER/AMS is meaningless when using /DT/AMS, but /DT/INTER/AMS can be used, instead of /DT/NODA/CST when contacts highly affect the time step.
  • Initial intersections and penetrations should be removed, as much as possible (as well as in traditional mass scaling, notably if it is used for comparison with the AMS results).
    CAUTION:
    Barriers, other impactors, and more particularly dummies contain a lot of interfaces that must NOT be modified since their validation is based on their original /INTER options (if modified, their validation is not guaranteed).
Rigid Bodies
  • Small rigid bodies inertia should rather be spherical with Ispher set to 1.
    CAUTION:
    Dummies contain a lot of small rigid bodies that must NOT be modified since their validation is based on their original /RBODY options (if modified, their validation is not guaranteed).
  • Flying nodes: are not a limitation but they should be removed, as well as unconnected small rigid bodies that are not needed.
  • Rayleigh damping: in few cases where the elastic domain remains large along the simulation, poor AMS performances with noisy time history curves (example, force-time) and Harlequin patterns in contour plots (example, von Mises) may be observed. A significant improvement should occur by inserting a Rayleigh damping card (/DAMP in the Starter file) affecting the parts subject to AMS using these parameters:
    α = 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHXoqycq GH9aqpcaaIWaaaaa@39BD@ and β = 0.05 Δ t A M S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHYoGycq GH9aqpcaaIWaGaaiOlaiaaicdacaaI1aGaaeiLdiaadshadaWgaaWc baGaamyqaiaad2eacaWGtbaabeaaaaa@4099@
    (with Δ t A M S MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaqGuoGaam iDamaaBaaaleaacaWGbbGaamytaiaadofaaeqaaaaa@3B0D@ is AMS target time step, so β is 5% times the AMS target time step). Such a modification may allow to increase the AMS target time step for much better AMS performances.
    Note: It is not advised to use numerical damping (dm or Navier-Stokes), instead of Rayleigh damping, here.
