/IMPVEL/LAGMUL
Block Format Keyword Defines imposed velocities on node groups using Lagrange multiplier method.
/IMPVEL/LAGMUL/impvel_ID/unit_ID
impvel_title
fct_IDT Dir Skew_ID   grnd_ID
Ascalex Fscaley
impvel_ID Imposed velocity block identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
impvel_title Imposed velocity block title.
fct_IDT Time function identifier.
(Integer)
Dir Direction: X, Y, and Z in translation; XX, YY, and ZZ in rotation.
(Text)
Skew_ID Skew identifier.
(Integer)
grnd_ID Identifier of the node group on which the imposed velocity is applied. Input is obligatory. The imposed velocities will be applied only on nodes that belong to a node group.
(Integer)
Ascalex Abscissa scale factor for fct_IDT.
Default = 1.0 (Real)
Fscaley Ordinate scale factor for fct_IDT.
[ms] MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaadaWcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ or [rads]
  1. The velocity direction must be right justified in the ten characters of field number 2.
  2. The translational velocity is not available, if it is applied on a node with a null mass.
  3. The rotational velocity is not available, if it is applied on a node with a null inertia.
