/IMPDISP/FGEO
Block Format Keyword Describes the final position of a set of N nodes, input by coordinates.
/IMPDISP/FGEO/impdisp_ID/unit_ID
impdisp_title
fct_ID part_ID   sens_ID
Ascale     Tstart Tstop
node_ID1 X1 Y1 Z1
etc
node_IDN XN YN ZN
impdisp_ID Imposed displacement block identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
impdisp_title Final geometry block title.
fct_ID Time function identifier.
(Integer)
part_ID Spring part identifier. 5
(Integer)
sens_ID Sensor identifier.
(Integer)
Ascale Abscissa scale factor for fct_ID.
Default = 1.0 (Real)
[ s ]
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
Default = 1030 (Real)
[ s ]
node_IDi Node identifier.
(Integer)
XN X coordinate.
(Real)
[ m ]
YN Y coordinate.
(Real)
[ m ]
ZN Z coordinate.
(Real)
[ m ]
  1. A displacement is imposed to node_IDN from its initial position provided in /NODE, to its final position (XN, YN, and ZN).
  2. fct_ID is a scale factor on the imposed displacement, it should vary between 0 and 1.
  3. Abscissa scale factor, Ascale is used to transform the function of time, as:(1)
    F ( t ' ) = f T ( t A s c a l e ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qaciGGgbWaaeWaa8aabaWdbiaadshapaWaaWbaaSqabeaapeGaai4j aaaaaOGaayjkaiaawMcaaiabg2da9iGacAgadaWgaaWcbaGaamivaa qabaGcdaqadaWdaeaapeWaaSaaa8aabaWdbiaadshaa8aabaWdbiaa dgeacaWGZbGaam4yaiaadggacaWGSbGaamyzaaaaaiaawIcacaGLPa aaaaa@45DC@
    Where, f T MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaciOzamaaBaaaleaacaWGubaabeaaaaa@3BC7@ is the function of fct_IDT.
  4. After Tstop, the nodes move freely.
  5. Initial node position N1 and final node position N2 can be defined as a spring N1N2 with zero stiffness. The spring part_ID is optional and can be used to simplify the input since a pre-processor can easily generate springs between an initial position and a final one.
