/IMPLICIT
Block Format Keyword This option allows different default values which are suitable for implicit calculations.
/IMPLICIT
Changed Values
Option Name Description New Value
/DEF_SHELL Iplas Shell plane stress plasticity flag 1 (iterative projection with three Newton iterations)
Ishell Shell formulation flag 24
Idril Drilling degree of freedom stiffness flag 1
/DEF_SOLID Isolid Solid formulation flag 14
/INTER/TYPE7 Irem_i2 Deactivate the secondary node flag 1
  1. Some default values are different in certain options. See /SPMD and /INTER/TYPE24.
