/GRPART/SUBMODEL
Block Format Keyword Describes the part groups which belong to given submodels.
Enter selected item numbers (any number may be input, 10 per Line)
/GRPART/SUBMODEL/grpart_ID
grpart_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
grpart_ID Part group identifier
(Integer, maximum 10 digits)
grpart_title Part group title
item_ID1, item_ID2,..., item_IDn List of submodel identifiers
(Integer)
  1. If item_ID is a negative number, the item number is deleted from the group.
