/GRPART/GENE
Block Format Keyword Generate a group of parts by listing the first and last part IDs in the range.
For each list, enter first node and last node (any number of lists may be input, up to 5 per Line). All nodes between first_ID and last_ID are selected.
/GRPART/GENE/grpart_ID/unit_ID | |||||||||
grpart_title | |||||||||
first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_ID5 | last_ID5 |
grpart_ID | Part group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grpart_title | Part group
first_ID1, last_ID1,...first_IDn, last_IDn | List of first and last
part identifiers (Integer) |
