/GRPART/MAT
Block Format Keyword Describes the part materials groups which belong to given materials.
/GRPART/MAT/grpart_ID | |||||||||
grpart_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
grpart_ID | Part group
grpart_title | Part group
item_ID1, item_ID2,..., item_IDn | List of material
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
