/GRNOD/NODENS
Block Format Keyword Describes the unsortable node number groups.
Enter node numbers in the desired order (any number may be input, 10 per Line)
/GRNOD/NODENS/grnd_ID/unit_ID
grnd_title
node_ID1 node_ID2 node_ID3 node_ID4 node_ID5 node_ID6 node_ID7 node_ID8 node_ID9 node_ID10
grnd_ID Node group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grnd_title Node group title
node_ID1, node_ID2..., node_ID10 List of secondary node identifiers
(Integer)
  1. Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
  2. Nodes are not stored by Radioss. This option is only needed in interface TYPE8 and /XELEM.
