/GRNOD/BOX
Block Format Keyword Describes the node box groups which are inside the box.
Only one box_ID is allowed:
/GRNOD/BOX/grnd_ID/unit_ID
grnod_title
box_ID
grnd_ID Node group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grnd_title Node group title
box_ID Box identifier, which is defined in Boxes
  1. Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
  2. Nodes are stored in this order. For all other input types, nodes are sorted.
  3. If type is BOX, all nodes inside the box are selected.
