/GRNOD/GEN_INCR
Block Format Keyword Generates a group of nodes by listing the first and last nodes IDs in the range with a user-defined increment value.
Generate a list of entities that starts with first_ID and includes entities every Incr after first_ID until last_ID.
/GRNOD/GEN_INCR/grnd_ID/unit_ID
grnd_title
first_ID last_ID Incr
grnd_ID Node group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grnd_title Node group title
first_ID First node identifier in the list.
(Integer)
last_ID Last node identifier in the list.
(Integer)
Incr Increment value of the list generation from first_ID to last_ID.
Default = 1 (Integer)
  1. Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
  2. The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
  3. Multiple first_ID, last_ID, and Incr lines can be defined in one block.
