/EOS/SESAME
Block Format Keyword Describes the SESAME table equation of state.
/EOS/SESAME/mat_ID/unit_ID
eos_title
E0 ρ0
SESAME301
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
eos_title EOS title.
E0 Initial energy per unit reference volume.
(Real)
[Jm3]
ρ0 Reference density.
Default = material density (Real)
[kgm3]
SESAME301 File name for SESAME table #301.
(Character)
  1. unit_ID does not apply to the table which should be given in its native units: 1
    Density: [gcm3]
    Pressure: [GPa]
    Energy: [MJkg]
  2. The table is automatically converted in the Work Unit System, defined in the /BEGIN keyword.
  3. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
    • /MAT/LAW3 (HYDPLA)
    • /MAT/LAW4 (HYD_JCOOK)
    • /MAT/LAW6 (HYDRO or HYD_VISC)
    • /MAT/LAW10 (DPRAG1)
    • /MAT/LAW12 (3D_COMP)
    • /MAT/LAW49 (STEINB)
    • /MAT/LAW102 (DPRAG2)
    • /MAT/LAW103 (HENSEL-SPITTEL)
1
"Handbook of Material Properties Data Bases", Los Alamos National Laboratory, 1984.
