/DFS/DETPOINT
Block Format Keyword Locates the detonation point and set lighting time for an explosive material law.
/DFS/DETPOINT/detpoint_ID/unit_ID
XDET YDET ZDET TDET mat_IDDET
detpoint_ID Point detonator identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier
XDET X coordinate.
Default = 0.0 (Real)
[ m ]
YDET Y coordinate.
[ m ]
ZDET Z coordinate.
[ m ]
TDET Detonation time.
[ s ]
mat_IDDET Explosive material number concerned by detonation time.
= 0 (Default)
All /MAT/LAW5 (JWL) material law are affected by the detonation time.
(Integer)
  1. It is possible to define multiple detonation points.
  2. If a detonation point is not defined, JWL material law will instantaneously detonate.
  3. Detonation times are available in the Starter output file (IPRI ≥ 3).
  4. Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
