/ALE/GRID/VOLUME
Block Format Keyword Ale grid smoothing formulation is based on volume. Each ALE node position is computed as the average position of the centroids of the elements to which it is connected. The volume of the elements is used to weight the average positions.
/ALE/GRID/VOLUME
  1. Boundary conditions for the ALE grid smoothing have to be imposed (/ALE/BCS).
