/ALE/GRID/LAPLACIAN
Block Format Keyword ALE grid smoothing using the Laplacian smoothing method for 2D and 3D elements.
/ALE/GRID/LAPLACIAN
λ Niter
Definition
λ Scale factor for grid update. 1
Default = 1.0 (Real)
Niter Number of iterations.
Default = 1 (Integer)
  1. The grid is smoothed using the formula:(1)
    P i P i + λ Δ P i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaamiua8aadaWgaaWcbaWdbiaadMgaa8aabeaak8qacqGHqgcRcaWG qbWdamaaBaaaleaapeGaamyAaaWdaeqaaOWdbiabgUcaRiabeU7aSj aabs5acaWGqbWdamaaBaaaleaapeGaamyAaaWdaeqaaaaa@4230@
    Where, λ [ 0 , 1 ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaeq4UdWMaeyicI48aamWaa8aabaWdbiaaicdacaGGSaGaaGymaaGa ay5waiaaw2faaaaa@3D7A@ is a user parameter with a default value of 1.00.(2)
    Δ P i = 1 N connected j=1 N connected P j P i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaaeiLdiaadcfapaWaaSbaaSqaa8qacaWGPbaapaqabaGcpeGaeyyp a0ZaaSaaa8aabaWdbiaaigdaa8aabaWdbiaad6eapaWaaSbaaSqaa8 qacaWGJbGaam4Baiaad6gacaWGUbGaamyzaiaadogacaWG0bGaamyz aiaadsgaa8aabeaaaaGcpeWaaybCaeqal8aabaWdbiaadQgacqGH9a qpcaaIXaaapaqaa8qacaWGobWdamaaBaaameaapeGaam4yaiaad+ga caWGUbGaamOBaiaadwgacaWGJbGaamiDaiaadwgacaWGKbaapaqaba aaneaapeGaeyyeIuoaaOGaamiua8aadaWgaaWcbaWdbiaadQgaa8aa beaak8qacqGHsislcaWGqbWdamaaBaaaleaapeGaamyAaaWdaeqaaa aa@5935@
  2. Several iterations may be defined, but usually 1 iteration per cycle is enough (Niter=1).
