Linked Surface Sweep
This feature makes the task of sweeping many surfaces at the same time easier. An additional benefit is that animations of multiple swept surfaces can be created with a single mouse button click.
Sweep actions of a current coordinate surface will affect all other coordinate surfaces, including all datasets in an AcuFieldView session. Similarly, sweep actions of a current iso-surface will affect all other iso-surfaces, and sweep actions of a current computational surface will affect all other comp surfaces. When the Linked Surface mode is turned on from the Tools menu, control of all like surfaces is from the sweep controls section of the current surface.
