Execute FVX File
The Execute FVX File action will read and execute an AcuFieldView Extension language (FVX) program.
When you select this option, you will be presented with a file selector so that an FVX file may be selected. Upon file name selection, the program is read in and execution begins immediately. If there are any errors, the debugger output displays the details on the error.
