Toolbars
Toolbars contain groups of icons used to perform the most common tasks.
Main Toolbar
Icon | Behavior |
Open or read a complete restart file for import |
Save a complete restart file |
Direct printing |
Opens the Function Specification panel |
Opens the Scalar Colormap Specification panel |
Opens the Color Mixer panel |
Transform Controls Toolbar
Icon | Behavior |
Center the image |
Opens the Defined Views panel |
Refresh the window |
Toggle the display on and off |
Viewer Toolbar
The Viewer toolbar allows you to use the mouse to translate and transform various items that make up your visualization. There are several different modes and many of the modes have different icons and actions. The various modes are activated based on the current Object and settings on the View menu and Viewer Options panel. The toggle next to Object controls the object that is affected by the view transformations.
Figure 3.
Icon | Behavior |
Toggle between locked transforms controls and multi-transform controls |
Combined screen XY Translation (X translation is horizontal movement, Y translation is vertical movement) |
XYZ rotation |
Used for magnification when Object is World and Scaling when Object is Dataset |
Side (Visualization) Toolbar
Figure 4.
Window Toolbar
Figure 5.
