Manufacturing Solutions
DEFORM Utility Menu
DEFORM Utility Menu
DEFORM Utility Menu
Shortcuts to many commonly-used panels and tools are available from the Deform Utility menu. The macros are arranged in process order, from top to bottom.
macro_menu_forging
Model
CAD/HM/FE
Import CAD drawing, a HyperMesh file, or a finite element file.
R-Mesh...
Opens the Rigid Tool Surface Meshing dialog.
Mesh
Opens the Automesh panel, to create meshes automatically or interactively.
Tetramesh
Opens the Tetramesh panel, to create a mesh of tetrahedral elements.
Setup
Materials
Opens the Materials panel.
Flow Stress
Opens the Materials Flow Stress Data dialog.
Comps
Opens the Collectors panel
Contacts
Opens the create subpanel of the Interfaces panel.
Symmetry Plane
Opens the Symmetry Plane dialog from which you can specify only a part of the geometry of a symmetrical model to use for the simulation.
Tool Position
Opens the Tool Position dialog, on which you specify two parts that definition a change in position, and the direction of the approach in order to adjust the position of the assembly parts to achieve an efficient process.
Depending on the original location and orientation of the billet with respect to the dies, you may need to use additional tools (available in the Manufacturing Solutions menu bars) to correctly position the billet with respect to the tooling.
Tool Motion
Opens the Tool Motion dialog.
Save
Opens the Files panel, from which you can save your model file.
Export
Opens the Select the file to export dialog, on which you specify a location to save the .KEY file. Select this macro to export your DEFORM input file.
See Also:
Setting Up a Forging Simulation
Modifying Model Geometry
Meshing the Model
Applying Material to the Parts
Defining Contact Interactions
Creating a Symmetry Plane
Defining the Tool Motion
Creating a Solver Input Deck (.key file)
