Manufacturing Solutions
Defining the Tool Motion
You must define the tool motion before you run your analysis. The parameters that define the tool motion are set on the Tool Motion dialog, which is accessed by the Tool Motion macro. These parameters describe which component represents the moving tool, the type of motion, unit vectors, and the speed or load.
See Also:
Tool Motion Dialog
Forging User's Guide
