Manufacturing Solutions
DEFORM User's Guide
DEFORM User's Guide
DEFORM User's Guide
DEFORM is a subprofile of Forging that helps you prepare input decks for the analysis of three-dimensional deformation or heat transfer simulations with the DEFORM solver.
This guide includes the following topics:
Setting up a Forging Simulation
DEFORM Utility Menu
Modifying Model Geometry
Applying Materials to the Parts
Meshing the Model
Defining Contact Interactions
Creating a Symmetry Plane
Defining the Tool Motion
Creating a Solver Input Deck (.key file)
Control Cards
Supported Keywords
Terminology
See Also
Tutorial: Modeling Hot Isothermal Forging Simulation for a T-Joint
