Manufacturing Solutions
Modifying Model Geometry
After importing a model file, you can modify the model’s geometry to prepare it for meshing. The Geom Cleanup macro on the Utility menu opens the Geom Cleanup panel, from which you can modify edges, find and delete duplicate surfaces, add fixed points to surfaces, etc. You must have clean model data in preparation for a forging analysis.
You can also use HyperMorph to perform design studies or make rapid/large changes to the model geometry.
See Also:
Meshing the Model
Applying Material to the Parts
Defining Contact Interactions
Creating a Symmetry Plane
Defining the Tool Motion
Creating a Solver Input Deck (.key file)
Using HyperMorph
