Manufacturing Solutions
Tool Motion Dialog
Tool Motion Dialog
Tool Motion Dialog
Use this dialog to define the moving tool. The following fields and buttons appear on the Tool Motion dialog. Refer to the DEFORM documentation set for more details about the parameters you set here.
Field
Moving tool
From the list, select the tool that will have the defined motion.
Moving control type
Choose whether the motion is controlled by speed or load.
Unit vector in X direction
Type a value for the unit direction vector for movement in the X direction.
Unit vector in Y direction
Type a value for the unit direction vector for movement in the Y direction.
Unit vector in Z direction
Type a value for the unit direction vector for movement in the Z direction.
Speed/load
Type a value for the speed or load. The value is interpreted as load or speed according to which value is selected in the Moving Control Type field.
Max stroke
Type a value that is the amount by which the top die must move to complete the forging. Note that you must also provide an appropriate gap for the flash.
Apply
Applies the current settings to the simulation.
Close
Closes the Tool Motion dialog.
See Also:
Forging Utility Menu
