Manufacturing Solutions
Symmetry Plane Dialog
Use this dialog to define a plane of symmetry to create constraints on the nodes. These constraints are useful for limiting the simulation to a particular section of a symmetric model.
Field
Select symmetry plane
Select the plane to bisect to define the symmetry.
Tolerance
Type a distance by which symmetry nodes will be detected.
Create
Creates the symmetry plane. You will be prompted to select a node on the model by which the line of symmetry will be drawn.
Cancel
Closes the Symmetry Plane dialog.
See Also:
Forging Utility Menu
