Solver Cross-Sections
Create solver cross-sections on the seatbelt mesh.
Creating cross-sections allows you to automatically create solver cross-sections at a given distance from the start and end of the seatbelt.
  1. Select the appropriate seatbelt entity in the Seatbeltブラウザ, right-click and select Create Cross Section from the コンテキストメニュー.
  2. Under the Located At section in the エンティティエディター, type in values for the Distance from Start and Distance from End fields.
  3. Click Create.
    図 1. Cross Section
