Seatbelt System
Use the Seatbeltブラウザ to create a complete seatbelt system.
制約事項: Only available in the LS-DYNA,
Radioss and PAM-CRASH
solvers.
From the メニューバー, click Tools > Seatbelt.From the 安全解析 ribbon, click the Seat Belt tool.From the メニューバー, click Safety > Seatbelt.
図 1.The Seatbeltブラウザ opens. -
To undo or redo actions, use the
Undo and Redo commands on
the Restore toolbar.
The Seatbeltブラウザ consists of two panes. The upper pane is the Seatbelt System structure and the lower pane is the エンティティエディター.
- Add or remove columns in the Seatbeltブラウザ as necessary by right-clicking on a column and checking or unchecking the appropriate attribute.
- You can sort entries in the ブラウザ by clicking on the appropriate heading of each column. For fields that are numeric or alphanumeric, repeated clicks toggle between ascending and descending order.
Create a seatbelt system:
In the Seatbeltブラウザ pane, in empty space,
right-click and select Create > SeatbeltSystem.
A seatbelt system is created and displayed in the ブラウザ.
Edit the seatbelt system entity as necessary by setting or changing
values in the エンティティエディター.
For more information on seatbelt entities and attributes, see Seatbelt Browser Entities and Attributes.
To update a seatbelt system, right-click on the appropriate
SeatbeltSystem entity and select
Update from the コンテキストメニュー.
Updating allows you to make changes on demand. For example, when the dummy and seat positions have been modified (when the option Link Dummy Mechanism in the seatbelt system entity editor is OFF).
Run a penetration check on the system by right-clicking on the appropriate
SeatbeltSystem entity and selecting
Penetration Check from the コンテキストメニュー.
A penetration check allows you to directly check the generated contact for penetrations after a seatbelt mesh has been generated and the option Create Contact is activated.
