VectorFromScalar
Creates a vector from three scalar tables and stores the result in answer.
x
A scalar value table.
y
z
sysid
A system ID or keyword (default = 0).
Outputs
answer
A vector value table.
  • x, y, z, and answer must be real bound to the same entity type, and of the same domain (complex or real).
  • sysid is a string containing an ID or keyword that defines the system the vector will be created relative to:
    • “0”: Global (the default)
    • A positive integer: a system ID in the model
    • “elem”: the elemental coordinate system
    • “anal”: the nodal analysis system
    • “ply”: the elemental ply system
    • “mat”: the elemental material system
  • If x is a constant value table (created by the Constant operator), no records will be added to the answer table.
  • If a record cannot be found in all three input scalar tables, no vector will be created.
VectorFromScalar(xs,ys,zs)
XML Example
<call name="VectorFromScalar" x="xs_tab" y="ys_tab" z="zs_tab" answer="ans_tab" />
