Cross
Stores the vector product of lhs and rhs into answer.
lhs
A vector value table.
rhs
Outputs
answer
  • lhs, rhs, and answer must be in vector format.
  • If lhs is a constant value table (created by the Constant operator), no records will be added to the answer table.
cross(lhs,rhs)
XML Example
<call name="Cross" lhs="lhs_tab" rhs="rhs_tab" answer="ans_tab" />
