VectorLocalToGlobal
Transforms vectors relative to a local system to the global system.
src
A vector value table.
nodes
A node entity table.
coords
A coordinate vector value table.
systems
A system entity table.
elemSysMethod
The element system method for the model. Valid values are "Bisect" (default value) or "Midpoint" (to be used for all Radioss models).
Outputs
answer
  • All vectors in coords must be relative to the global system.
  • nodes and src tables must be in the same pool.
  • elemSysMethod is only applicable for Element-bound vectors and is specific to quadrilateral elements only.
VectorLocalToGlobal(src,systems,nodes,coords,elemSysMethod)
XML Example
<call name="VectorLocalToGlobal" src="vec_tab"
nodes="node_tab" systems="sys_tab"
coords="coord_tab" answer="ans_tab" />
