Globalize
Resolves coordinates and system transformations with respect to the global coordinate system.
nodes
A node entity table.
coords
A coordinate vector value table.
systems
A system entity table.
Outputs
coords
A coordinate vector value table (in/out).
systems
A system entity table (in/out).
  • Systems and coordinates relative to non-global systems will be transformed to the global system.
  • This operator should be called within the model/commit block to insure all systems and coordinates are properly transformed to the global coordinate frame.
  • All vectors in coords must be relative to the global system.
  • This operator is not available in the expression builder.
N/A
XML Example
<call name="Globalize" nodes="node_tab" systems="sys_tab"
coords="coord_tab" />
