Power
Stores src raised to the power of exp in answer.
src
A value table.
exp
The exponent.
Outputs
answer
A value table.
  • src and answer must be of the same binding and format.
  • If a value in src is large enough to cause a floating-point overflow, no record will be added to answer.
  • If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
src ^ exp
XML Example
<call name="Power" src="src_tab" exp="3" answer="ans_tab" />
