Log
Stores the log of src in answer.
src
A value table.
base
e or 10 (default is 10).
Outputs
answer
A value table.
  • src and answer must be of the same binding and format.
  • If a value in src is large enough to cause a floating-point overflow, no record will be added to answer.
  • If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
log(src,base)
XML Example
<call name="Log" src="src_tab" base="e" answer="ans_tab" />
