ScaleParticipation
Scales the participation values to ensure that contour patterns stand out.
projected_participation
A scalar or vector value table to be scaled.
logrefval
A log scaling reference value (1.0, .1, .01, .001, or .0001).
Outputs
answer
A scalar value table.
  • projected_participation is the participation component to be scaled for contour.
  • logrefval defaults to 1.0, meaning no log scaling, only scaling by the max value.
ScaleParticipation(projected_participation,logrefval)
XML Example
<call name="ScaleParticipation"
projected_participation="projpart_tab" logrefval="1.0"
answer="@usgp_ret" />
