ExtractParticipation
Extracts the specified participation component.
normalized_participation
A scalar or vector value table.
total_response
The ID of the node where the total response will be used for projection.
direction_component
Directional component of the participation value to be extracted (default = "XYZ").
complex_component
Complex component of the participation value to be extracted (default = "Proj").
Outputs
answer
A scalar value table.
  • normalized_participation is computed by dividing the elemental participation by shell area, from which the specified participation component is to be extracted.
  • direction_component can be any directional component (“x”, “y”, or “z”), or the entire vector (“xyz”). “xyz” is the default.
  • complex_component controls how scalars are extracted from complex participation values. Valid options are “proj”, “mag”, “phase”, “real”, and “imag”. The default is “proj”.
ExtractParticipation(normalized_participation,total_response, direction_component,complex_component)
XML Example
<call name="ExtractParticipation"
total_response="total_resp_tab"
normalized_participation="area_norm_tab"
direction_component="x" complex_component="mag"
answer="ans_tab" />
