NVToPartRMS
Calculates the RMS value of the absolute value of complex vector components per part.
src
A complex nodal vector.
elems
An element entity table.
Outputs
answer
A part-bound scalar value table.
  • Nodes without values do not contribute to the average.
  • The rms value is computed as follows (per part):
    sqrt( sum(ss_nv)  / num_nv)
    where:
    sum(ss_nv) = sum of squared components of src.
    num_nv = number of values in each part.
NVToPartRMS(src,elems)
XML Example
<call name="NVToPartRMS"
src="nvel_tab" elems="elems"
answer="@ans_tab" />
