Integrate Panel
Use the Integrate panel to obtain the area under a curve. The area under the curve that has been integrated is shaded and the total area, based on the calculation, is given.
Panel Options
Option Action
plot = Click the button or text box to display a list of plots in the model, then select the desired plot.
curve = Click the button or text box to display a list of curves in the model, then select the desired curve.
from: x = The starting point on the curve for the area you wish to calculate. Integration will be calculated between this point and to: x=.
to: x = The ending point on the curve for the area you wish to calculate. Integration will be calculated between this point and from: x=.
area = This read-only field displays the total area calculated under the curve between the from: x = and to: x = points.
avg height = This read-only field displays the average height of the curve between the from: x = and to: x = points.
Command Buttons
Button Action
integrate Perform the calculation on the selected curve between the specified points.
return Exit the panel.
